Conformal LEC renaming rule
dhivyanandhini
Newbie level 5
INDIA
Hi would like to change
txdata_reg[0] to txdata_reg[3] in golden for unmapped points
my renaming command is not working...
add renaming rule r1 "txdata_reg[0]" "txdata_reg[3]" -Golden -map
may i knw wat changes to be made....
Thank you
"add mapped points gold_point revised_point -noinvert"
should work?
txdata[3] of revised is already mapped with txdata[3] of golden....
iam comparing 2 netlist
unoptimized one and optimized one....
in optimized the txdata[0] is optimized and removed whereas txdata[0] remains in unoptimized...
is thr any method to map the txdata[0] to txdata[3].....
find out the reason why it is optimized in netlist...use that modeling swithc with set flatten model command....this point will go away and you will get clean results
hey thanks....
i used flatten model -all_seq_merge option.....
it solved my problem!!!
change the value back to the default value or say No
For e.g to the one used above
set flatten model -no_seq_merge (this is default)
Similarly LEC has options for all modelling directives which can be used in your dofile
