Wat i mean is i have already designed a conformal patch for 22GHz band but for improvement in the omni radiation pattern in azimuth and the two elevation i might have to increase the thickness of the conformal patch. How would i do it in CST Microwave Studio??
A good advice is to get used to parametrize your structures. if not already parametrized (which is the case I guess) that would help if you post your project.
sorry for my previous post, I missed your point.
To increase the thickness of a conformal antenna I would duplicate the sheet, then add an offset and at the end use the loft function to make a conformal solid. It is maybe worth to give it a try (I don't have access to MWS this week-end).
