config file for IC5141???
K
krivan
I'd like to make some parameters [like undo limit -> 10] set automatically when I start the IC5141 Cadence version.
I haven't found any appropriate config file where I could have changed it.
Does somebody know how I can set the parameters in advance, or could somebody please send me a startup file template?
Thanks,
Krivan
add this line to your ~/.cdsenv
ui undoLevel int 10
other useful things which may not be on by default
ui showOptionForms boolean t
ui beepVolume int -100
ui infix boolean t
ui showScrollBars boolean t
if your .cdsenv is not in your home directory, make sure to add the following line to .cdsinit in your cadence folder:
envLoadFile(“/<path_to>/.cdsenv”)
the template is located in $CDS_HOME/tools/dfII/samples
    K
krivan said:
Does somebody know how I can set the parameters in advance? Krivan
You can also do this via the CIW:
Options -> User Preferences... ... and after changing the settings:
Options -> Save Defaults...
