Computing IO grid information
kumar123
Member level 3
Hi
is there any formula to compute IO grid information(dimention) depending on M1,M2 and VIA1 VIA2 ..etc DRC rules ?, if so please do let me know the formula which governs the X-axis and Y-Axis IO grid values ( some times these two may not be same rite)
thanks & Regards
kumar
layout_designer
Member level 5
Are you working on standard cells or IOs?
Grid calculation is done in std cells.
kumar123
Member level 3
exactly requirement is for Std Cells and we do call that grid as IOgrid rite
thanks
kumar123
Member level 3
Hi any information on this ? for standard cells structure
layout_designer
Member level 5
Tentitively I think this is how you calculate:
For example,
contact size -a*a,
min space between two m1- b
overlap of m1 over contact- c
grid=1/2a+c+b+c+1/2a
i.e centre of one contact to another
kumar123
Member level 3
For example,
contact size -a*a,
IS this horizantal or veritical because it is not necessary that both are of same value is itn't !
