automatically printout pc restart
Luckily only Computer Power supply was damaged and no harm was made to processor,RAM,drives,etc. Computer guy checked up all the things and replaced the burnt up power supply with a new one.Now I am succesfully able to run my older system.I run the same program in older computer III Compaq Presario 6000 with built in serial port/parallel port using VB6. I was succesfully able to do the serial communication. But in my other computer Pentium 4 Core 2 Quad, my computer gets restarted. It seems like a strange problem to me.I had to ask one more question related to VB6 is that, it's related to programming issue. I'm dumping Hex values from 00 to FF. But I get around 4 to 5 digit hex using this program in text box.
Private Sub Command1_Click()
MSComm1.PortOpen = False
End
End Sub
Private Sub Form_Load()
MSComm1.CommPort = 1
MSComm1.Settings = "2400,N,8,1"
MSComm1.InputLen = 0
MSComm1.PortOpen = True
End Sub
Private Sub MSComm1_OnComm()
If (MSComm1.CommEvent = 2) Then
Text1.Text = MSComm1.Input
End If
End Sub
Please tell me what to do, actually in my circuit, I'm trying to make a real time plot, Analog to Digital conversion is going on my circuit and my microcontroller is dumping Hex values from 00 to FF to the computer serial port and by reading the values in VB6 I want to make the graph.
So first I am doing little exercise on VB6 like,
1)Do simple test on Serial Port
2)Make simple graph techinque
3)I have OCX file which makes graphing easy
4)I will do some test on programming and finally make a real time graph
So I'm going level by level to what I want to acquire in VB6. First test was to dump the values succesfull in it.
I'll try to figure out myself as why I'm getting 4-5 hex digit or more where as I should get 1 or 2 digits only.
I told this story of USB-Serial Cable problem to that computer guy, he has good knowledge in computer troubleshooting, programming experience in Visual Studio, C sharp and do work in Visual Basic 2005 and knows much about AutoCad and teaches Visual Basic in his institue. He told me his story, he told me that he purchased a Laser Printer and showed that to me, which runs on a parallel port, by it's look it seemed to me, as if the printer was Laserjet 6L, his new computer also didn't have parallel port, so he used the converter cable USB to Parallel, he told me that he takes out the printout from the printer, but he said he saw some garbage too in the print out paper. So he said to me, my USB-Parallel cable didn't work well. He further added that I hooked up my printer to my older computer which had parallel port and then printer showed no garbage on printout page and it worked perfectly.
I think the solutions of USB-Serial and USB-Parallel are 3rd party in nature. There drivers aren't 100% compatible and not fully functional.What should now I do, these ports aren't made any longer, they are now history. Is there any way I could still use converters with 100% compatablility, maybe the company of USB-Serial converter isn't good and they manufacture unreliable converter cable and their driver that came along with the cable is also unreliable. Have you ever had this kind of experience. Any suggestions, as what should I do now.
