Complementary Self Biased Compartor Design
kah89
Junior Member level 2
I am trying to design very low power self biased comparator like the one in the attached picture and I am loading the output with two inverters
I need to know what is the design procedures I have to follow also any materials would help a lot
Thank you.
Did you get this circuit from paper?
Here's another one with a nice description.
I got it from Bazes paper , Thank you for the document but still I don't know how to determine the sizing of the transistors
I tried to design one it operates only when the input voltage is high
Part 3 of the above linked document gives you optimization hints for the W/L ratios.
The necessary W/L ratios essentially depend on the process used, its p/n mobility ratio, and your priority either for speed, ICMR, or sensitivity.
For more help you should unveil this info, and the design schematic you've used so far.
    V
My priority is for power and speed I attached the same schematic I have used 111.png
Low power and speed are two opposing trends - you have to decide on a compromise.
Without mentioning your process, and without your W/L ratios, it doesn't make much sense.
Low Power is my first
The process is UMC 0.13 and I am using minimum sizing for all transistors (3.3 transistors, W/L=160n/340n)
I am still a beginner in design so I really appreciate your help
I don't have the UMC 0.13 models, so I tried with 0.18µm models. I think you could use the W/L ratios, perhaps scale them down a bit. But don't use min. size transistors (if you don't need max. speed).
Note:
I've used just one additional inverter, guess that's enough. In this case, the pos. and neg. inputs have to be swapped (relating to Vout1).
The ICMR is only about VDD/2 ± 250mV .
I think you could start from this schematic.
Reactions: kah89
    kah89
Note:
Thank you very much it works now, but one last thing when I increase the supply it doesn't work properly. Thanks again
... when I increase the supply it doesn't work properly.
In this case decreasing the W/L ratios of M3 & M4 in proportion to the "inner" transistors may help:
Note:
  • I've scaled down the W/L ratios by a factor of 2 - these should be fine for your 0.13µm process, I hope.
  • Now a 2nd inverter stage is needed.
  • The ICMR is shown in the image.
  • As you know, I've used 0.18µm models. The circuit might not work with your models.
Good luck!
Reactions: kah89
    kah89
Note:
Good luck!
Thank you very much I really appreciate your help
I have a problem with this comparator, as long as the input is lower than half of the supply it doesn't work properly?
Try to adjust the width ratio W(PMOS)/W(NMOS) to the low-field mobility ratio U0(NMOS)/U0(PMOS) of your process. It's probably close to 3 . You can find the U0 values in your models.
I did but with the same problem, Why the input has to be greater than half of the supply?
This depends on individual W/L ratios, and of those ratios between the transistors. Play with them! Try increasing M4 and/or decreasing M3. See if this works in the required direction, and iterate, if necessary.
