Comparison of HFSS and EMPIRE software
ranjithkumarr
Newbie level 3
tell your suggestion regarding the comparison of HFSS Vs EMPIRE 3D Electromagnetic simulation software.
HFSS Vs EMPIRE
except for the reputation of HFSS, I think that you should focus mainly on the numerical techniques they use. HFSS uses FEM and EMPIRE uses FDTD. FEM is known of its ability to tackle strongly resonant structures. whereas FDTD is very good for large open structures
Re: HFSS Vs EMPIRE
I would suggest neither of them. Both of them have very unintuitive user interfaces and workflows.
HFSS Vs EMPIRE
Hfss should be more accurate!
Re: HFSS Vs EMPIRE
Hi all!
I agree with irfan1 in parts. HFSS and Empire interfaces are both non-intuitive. I used both software packages. However there is a significant difference: After a week or so you can handle HFSS and generate reliable results. After 4 weeks with Empire you are still left in the dark. The most intuitive interface has CST MWS. That is my experience.
Re: HFSS Vs EMPIRE
In addition, CST MWS has a very good manual with a lot of tutorials. Moreover, help of MWS is the best I have seen.
Re: HFSS Vs EMPIRE
You can look at this forum. There are a lot of Question in HFSS construction and few in MWS
That’s show something ????????
PL
Re: HFSS Vs EMPIRE
It really depends on your application (as suggested above) HFSS is very memory hungry as you increase the mesh size, time domain codes such as Empire increase linearly with number of cells.
Cost is also something to look at (although I suspect many people here aren't using licenced copies, judging by some questions), HFSS is very expensive, EMpire is not.
Also to emphasise other people, if you're looking for an intuitive easy to use interface, MWS is your only real option (now with 4 solvers in one interface)
Re: HFSS Vs EMPIRE
HI,
as an alternative, you may want to give a look to MICROSTRIPES, 3D EM Solution, using Transmission Line Matrix (TLM) method to solve Maxwell’s equations in the time domain!
their GUI is pretty stright forward and is appreciated to be fast and very accurate thanks to their solver. http://www.flomerics.com/microstripes
gook luck
AW
Re: HFSS Vs EMPIRE
3dandyw said:
HI,
their GUI is pretty stright forward and is appreciated to be fast and very accurate thanks to their solver. h**p://www.flomerics.com/microstripes
gook luck
AW
I agree with you. Microstripes by flomerics is more userfriendly than HFSS. The need of memory is less than HFSS, so microstripes can run faster than HFSS for the same design. I used microstripes to design my microstrip antenna. Anyone have suggest for other simulator that is more efficient than microstripes?
