i have been working in keil for the past 5 month, and i have some doubt about the sartup.a51 and init.a51 code in the toolchain of c51 in keil compiler,
1. What is the purpose of these 2 codes for a project?
2. whether we need to use both 2 codes in one project?
3. What is the order of linking with the target in compiler?
I've worked with code that doesn't use STARTUP.A51 and INIT.A51 but those codes did have parts that handle the function of these 2 files. Cypress firmware framework for FX2LP is one such example.
Cheers,
Anand
