[SOLVED] comparing unsigned numbers
nsgil85
Member level 4
Hi everyone
What is the syntex for comparing 2 unsigned number with diffrent length
for example:
signal sig_A :unsigned(3 downto 0) := to_unsigned(1, sig_A 'range) ;
signal sig_B :unsigned(2 downto 0) := to_unsigned(3, sig_B 'range) ;
if sigB > sig_A then
will i need to convert both numbers first to integer and then compare?
Thanks
Gil
vGoodtimes
you can compare unsigned values of different length, there are no special requirements. The greater/less operators will treat the comparison as a numeric comparison between unsigned values.
Some developers will also compare std_logic_vectors of equal length using greater/less. The comparison is done lexically, which matches a comparison between unsigned values. But only when the values don't have 'Z' or 'X' or etc... and are of equal length.
Basically, there is no need to change sizes if the types are "unsigned". You may see people resize the values because they had issues (incorrectly) comparing std_logic_vectors in the past.
TrickyDicky
Advanced Member level 5
Unless you're using the non-standard std_logic_unsigned library (or the standard 2008 library numeric_std_unsigned) then the results from this can be counter intuitive and give odd simulation results. I highly recommend you use the numeric_std library type unsigned.
nsgil85
Member level 4
thank you for the advice
Ok, so what can be done to compare variable with signal unsigned type?
BTY
I use numeric_std lib
Gil
c_mitra
This is strongly compiler dependent; if in doubt use assembler instructions (perhaps inline)
TrickyDicky
The OP is talking about HDL - not CPU programming!
HDL has no assembler instructions.
You can just compare two unsigned directly. No need to modify anything about them.
Do you have a specific use case you want help with?
nsgil85
Member level 4
No assembler for today :)
TrickyDicky, yes as following:
signal sig_C :unsigned(2 downto 0) := to_unsigned(3, sig_C 'range) ;
process:
variable var_D :unsigned(3 downto 0) := to_unsigned(1, sig_D 'range) ;
begin
if var_D > sig_C then
thanks
Gil
TrickyDicky
What exactly do you want help with - it should work as written - always false because 1 is not greater than 3
nsgil85
Member level 4
found my mistake, it didn't compile due to range issue,
Thanks
