Register Log in
comparators - pull up or not ?
rompelstilchen
Full Member level 2
fdsf
hello
I ordered LMV358IDR comparators to drive FDN340P transistors like on the following schematic
https://www.arduino.cc/en/uploads/Main/arduino-uno-schematic.pdf
but I find it ackward that there is no pullup resistor, I read many times a comparator needed one
- does it ?
- since the comparator appears to be powered by 5V USB, if there is no USB plugged in, is it's output low by default, so the FET is open letting any VIN supply go through ? how can I be sure of this ?
regards
FvM
Super Moderator
Staff member
Bochum, Germany
LMV358 are rail-to-rail OPs, not comparators, but can be of course used as comparators as well. The output is push-pull, no pull-ups required or useful.
The OP can work for the application, but I wonder why you don't use single channel LMV321?
KlausST
Super Moderator
Staff member
rompelstilchen
Full Member level 2
fdsf
actualy I have 2 usb connectors, one for a teensy , one for an arduino
they dont have any USB power switching
and indeed I should have ordered 321
can you answer my 2nd question too?
appreciate your help
it's the official arduino schematic, so I'll reproduce it
but I was wondering what about no USB power -> no power for the comparator -> what is the state of the FET transistor ?
FvM
Super Moderator
Staff member
Bochum, Germany
The comparator is powered by +5V node, derived from Vin and Vusb. In so far I don't understand the question.
You should pay attention to the MOSFET direction. It's main function is block reverse feeding the USB from VIN. It switches off if Vin > 6.6V, not strictly the expected safe behavior of an USB client according to USB standard.
rompelstilchen
Full Member level 2
fdsf
if USB (through mosfet) and VIN (through VREG) both produce 5V and reach the same 5V point in the schematic
then a simple diode would do the trick, right ?
Toggle Sidebar
