Comparator design - input, Vin & Vref, specific gain
Monady
Full Member level 1
Comparator design
i heard that if we use of open loop opamp as a comparator, it's not needed to use of input common mode for opamp inputs(without dc biasing) and only apply Vin & Vref.
is it true?
i think that if we need specific resolution, we must have specific gain.if we don't use of Vcmi, transistors will not be in saturation regime, thus we have not desired gain.
i don't know that which of these reasons is true.
jcpu
Full Member level 4
Full Member level 4
Re: Comparator design
Theoretically, yes, if the input stages gets saturated by DC, then the whole mechanism collapse.
In practice, comparator are not totally the same as opamp in that
we often add differential type cross-coupled latch stage before digital output buffer. And even in cases where input differential pair is not really in linear region we can get correct result since with cross coupled latch, never two output (positive / negative) shall both stay at same logic level (high / low).
Only thing to watch out is how much time it takes to resolve the difference of input signal level difference when it comes to small as mV.
Hope it helps,
    Monady
Monady
Full Member level 1
Comparator design
thnx for your reply.but if we don't use of dc biasing voltage for input transistors,is it possible to reach a specific gain that is mandatory for desired resolution?for example we must have a gain=1800 for Vin(min)=1mv in 0.18u technology(Vdd=1.8v).
jcpu
Full Member level 4
Full Member level 4
With above saying multi-stage, gain of a few thousands is not problem.
Another limiting factor of resolution is offset voltage (matching of input MOS).
We need to use size enough to make offset statistically small enough (say, less than 1mV).
Good Luck,
    Monady
