Compact and small Omni Directional wide band UHF antenna
madebyagra
Junior Member level 3
Indonesia
Hi there
can anyone help me to design or have ever designed omnidirectional antenna for UHF frequency,
I currently learning hfss sotware, so i'd thank for anyone that give some design and or tutorial how to design it..
Thanks before
hi
for UHF UWB antenna we some method like wipe to increase the bandwidth and some antenna like discone and biconical are fit for this application
Hi sir ferdows, my lecturer decided to apply ultra-wideband antenna technique in UHF television frequency range, and pardon me to ask if you have any reference about Ultra-wideband antenna fundamental itself, because i'm still confused about the difference of non-ultra wideband antenna and ultra wide band antenna
thanks
hi
whats the range of your antenna ?
it's ranged in 400 -800 MHz, and my lecturer want me to make an ultra wideband antenna that have bandwidth at this range (maybe 200 MHz- 2 GHz or etc, since i don't know how to shifting the frequency range (usually in 3.1 GHz-10.6 GHz) into the lower and desired one (covering 400 - 800 MHz),
