Communication between PC and FPGA kit with ethernet phy chip
akanekendo
Newbie level 2
Hello
I need to talk to an FPGA via on board ethernet port. The connection would be between an Altera Stratix IV GT, a Marvell 88E1111 and a PC. I have working knowledge with VHDL, quartus, and Labview.
My question is can I program only at the hardware level? I just need to read some data from the FPGA at sub-Mbps into a file. There is no need of data writing back.
I get the sense that I need to use TSE mega function. Do I have to implement a NIOS processor to talk to the module? on the PC side, does national instrument offer some driver for the Marvell chip?
thanks very much,
ak
Alexium
Full Member level 2
Ukraine
Yes you can. See MII interface specification (IEEE 802.3 standard).
As for the PC - there are libraries to do that. See LibPcap/WinPcap
akanekendo
Newbie level 2
follow up question.
If I program on the FPGA using MII protocol (I am assuming raw data plus some handshaking), do I need to use the package lib on the PC side? If not, what should I use?
