[SOLVED] communication between Matlab and FPGA virtex 5
Taki_comp
Member level 1
I am trying to implement an image acquisition system that communicates between Matlab and PC, the system works as follows: first of all matlab reads a grayscale image of resolution of 512x512 where the colors are 8-bit coded, the image then is segmented into 512 segments, each of them represents one row of the image. On the FPGA side, I used Ip core generator to generate a block of simple dual port RAM of size 512 bytes, this BRAM is interfaced with two UART interfaces; receiving interface and transmitting interface, the receiving interface receives 512 bytes and stores them in BRAM, then the transmitting interface sends back those 512 bytes to the Matlab software, this process is supposed to be repeated 512 times to send the whole image. Finally, the image received from FPGA is displayed on Maltab.
here is the vhdl code for the fsm used to control the operation of the UART
proc_next_state: process(clk, reset, state)
                 begin
		    if reset = '1' then
                       state <= idle;
		    elsif (rising_edge(clk)) then
		       case state is
		          when idle =>
			     count <= 0;
			     wea(0) <= rx_dv; -- set write enable equal to rx data valid signal
			     dina <= rx_byte; -- input of BRAM's port A.
                             ENB <= '0'; -- Enable signal for port B
			     tx_DV <= '0'; -- data valid signal for uart transmitting interface.
			     tx_byte <=(others => '0'); -- byte to be loaded to uart transmitting interface
			     if rx_dv = '1' then -- data valid signal for uart receiving interface
		                state <= writing; -- if rx_dv is asserted move to the writing state
			     else
			        state <= idle;							  -- keep idle
			     end if;
			  when writing =>
			     if addra = Addr_max then -- if the whole block is written move to the reading state
			        state <= reading;
			     else
			        state<= idle;
			     end if;
			     wea(0)<= '0';
			     dina <= rx_byte	;
			     ENB <= '0';
			     tx_DV <= '0';
			     addra <= addra + 1;
                             tx_byte <= (others => '0');
			  when reading =>
			     If count = 0 then
			        ENB <= '1';
			        tx_DV <= '0';
                                state <= reading;
			      elsif count = 1 then
			         ENB <= '0';
				 tx_DV <= '0';
				 state <= reading;
			      else
			         if addrb = addr_max then -- if the 16 bytes data are fully read move to state done
				    state <= done;
				 else
				    state <= waiting;
				 end if;
				 ENB <= '0';
				 tx_DV <= '1';
				 addrb <= addrb + 1;
			      end if;
			      tx_byte <= doutb;
			      wea <= (others => '0');
			      dina <= (others => '0');
			      count <= count + 1;
			   when waiting =>
			      count <= 0;
			      ENB <= '0';
			      tx_DV <= '0';
			      if tx_done = '1' then
			         state <= reading; -- read a new byte when tx_done is asserted high
			      else
			         state <= waiting; -- keep waiting
			      end if;
			   when others => -- remain in this state for one clock period then move to idle
			      wea(0) <= '0';
			      ENB <= '0';
			      tx_DV <= '0';
			      Addra <= (others => '0');
			      Addrb <= (others => '0');
			      pass_sig <= pass_sig + 1;
		              state <= idle;
		           end case;
			end if;
		     end process;
The Matlab code used to transmit and receive the image is shown below
ImgOrig = imread('Dome.gif'); % read the image into a matrix of dimension 512x512
ImgCopy = zeros(512,512);
 s = serial ('COM3');
 set(s,'baudrate', 115200);
 set(s,'Databits', 8);
 set(s,'stopbits',1);
 set(s,'InputBufferSize', 512);
 set(s,'OutputBufferSize', 512);
 set(s,'Timeout',120);
 dataWr = zeros(512,1);
 dataRd = zeros(512,1);
 i = 1;
   fopen(s);
 while(i<= 512)
           tic;
          for j = 1:1:512
              dataWr(j)= ImgOrig(i,j);
          end;
         fwrite(s,dataWr,'uint8');
         dataRd = fread(s,512,'uint8'); % data read from BRAM of FPGA
         for j = 1:1:512
             ImgCopy(i,j) = dataRd(j);
         end;
       i = i+1;
       toc;
 end;
 fclose(s);
Imshow(ImgCopy);
This is the picture of the Matlab command line after executing the Matlab program
As you can see the Matlab excutes the loop only 2 times, furthermore for the third iteration Matlab reads only 480 bytes so it remains busy until the timeout is elapsed, what are the possible reasons for this error ?
mjuneja
Bangalore, India
From the MATLAB workspace it seems that you are able to receive 480 bytes out of 512 bytes into dataRd....Have you tried increasing the timeout parameter of object s..Also(if your application allows) try to work at a baudrate of 9600bps or 19200bps as at such a high baudrate of 115200 bps noise can also come into picture.
And also try increasing the stop bits to 2.
Taki_comp
Member level 1
I tried all of what you mentioned in your reply and It didn't work
I'm using the uart just for testing purposes, in the futur I should switch to a faster protocol, besides I tried to send and receive one pack of 512 bytes and It was successful, what really makes me confused here is why was I able to send two rows, and then I received only 480 bytes out of 512 ? can the noise really affect the number of bytes received ?
mjuneja
Bangalore, India
Yes sometimes at higher baud rate while sending large amount of data, you tend to loose some data so better try to send data either at lower baud rate or try using ethernet interface for faster and noise-less transmission.
Taki_comp
Member level 1
I did reduce the bau rate to 9600 bps and it didn't work
Taki_comp
Member level 1
It turns out that there was nothing wrong with my design, I just switched to Atlys board and used Usb-uart bridge and everything worked just fine.
