Register Log in
communication between 16F877a and 24LC04B (external EEPROM) use i2c protocol??
slurp
Newbie level 6
Hello to all edaboard-ians,
Would like to ask some questions with regards to the above topic.
I am trying my hands on connecting and write/read between the PIC16F877a and the External EEPROM 24LC04B.
However, I DO NOT how to starts its I2C program/protocol.
Q1) To communicate between the PIC16F877a and the 24LC04B.
Is it necessary to have i2c protocol? [YES/NO]
Q2) I2C protocol refers to pulling HIGH/LOW the pins SDA and SCL? [YES/NO]
Q3) Is ti advisable to use Assembly Language (asm) or CCS (c-programming)?
Q4) any helpful sites?
I know, some may advise me to do more research and read-up. I did and still am doing then now...
I believe EDABOARD-ians would be another great source of information and help.
Thanking you in advance.
cheers,
slurp
ckshivaram
Advanced Member level 5
villingen (Germany) / Bangalore
A1. For any external eeprom communication I2c is required unless it supports SPI or any other protocol.
A2. Its not only pulling of the lines but the protocol has to be understood properly.
A3. Better to write it in C as it can be easy for tracing and understanding.. but you can also do it in asm..
Tutorial 10 - EEPROM Demo
---------- Post added at 12:16 ---------- Previous post was at 12:16 ----------
Here are some inforation from Micochip website
http://ww1.microchip.com/downloads/e...tes/00976A.pdf
Here is the assembler code example
http://ww1.microchip.com/downloads/e...otes/AN976.zip
And here is more information from Microchip website about i2c
http://ww1.microchip.com/downloads/en/DeviceDoc/i2c.pdf
slurp
Newbie level 6
Good-day ckshivaram,
Thank you for the detailed answers.
However, I tried to open your shared Tutorial 10 file, but i could not using MPLAB IDE.
Should I instead open it with the CCS?
What would you suggest for me to verify/see the External EEPROM's memory? Else How am I able to know it is successfully written and read correctly?
cheers.
Slurp
kandhu26
Member level 5
chennai / bangalore
This tutorial help you to understand I2C [Generic {Whatever the slave devices}] clearly...
slurp
Newbie level 6
Hi kandhu... What tutorial are you referring to? the one shared by CK?
cheers,
slurp
kandhu26
Member level 5
chennai / bangalore
That also useful... I am telling which is attached by me [I2C.pdf]... Both You can refer.... What i have attached is Generic I2C protocol..[Not specific to any particular slave devices..]
slurp
Newbie level 6
I am sorry Kandhu,
But I do not see any attachments of yours.
Anyhow, I would like to ask.
What are the CONFIG for 16F877 and 16F877a?
I am sure they are different, but I do not seem to get it from the datasheet.
cheers,
slurp
slurp
Newbie level 6
http://ww1.microchip.com/downloads/en/DeviceDoc/i2c.pdf[/QUOTE]
I want to thank you for sharing with me the above links.
I read the presentation by Microchip on the EEPROM AND THE pic INTERLINKING. (I2C)
I noticed that they only provide an example that write and read a ADDRESS AND DATA/..
i AM TRYING OUT TO write and read SEVERAL DATAsss.....by editing from the example given by microchip and added into it some looping.
Could you be of great help and assitance pleasE?
thanking you in advance.
cheers,
Natasha
andre_teprom
Super Moderator
Staff member
Brazil
dear slurp
CCS have a lot of helpfull examples ready-to-use concerning I2C memories ( 24Cxx ) once you had installed it to your PC.
Make a search on Help and examples folder.
dayanpad
Colombo
you will be easy to do it while you are doing it, therefore please install mikroC PRO for PIC and then you can see library Manager
and click I2C you will see lot of easy guide with cct
