diamadiss
Member level 1
I have a quiry about how can the two currents can exist as long as have the same direction for instance in Line and Neutral in a power supply (they created from an electromagnetic noise/signal which will add the same noise->voltage->current at both wire L & N)?
A current to flow must have to start from a high voltage point and to return to another lower voltage point... if these two currents are the same and have the same direction they will not "repelled" each other?
I read on the internet that they will flow both from a stray/parasitic capacitance to the PE(protective earth) but how a parasitc capacitance can exist from the supply PCB to the PE cable?
Also in order to eliminate the common mode noise they add two capacitors between Line & PE and between Neutral & PE in series with a common mode choke (filter) but if in "theory" the two currents have the same flow and will not have any path to flow why to place these two capacitors across PE? I hope I didn't tire you with my long text.
