monglebest
Junior Member level 1
I have the exact same problem as the below post, don't understand why the thread is closed and I still have no clue why I have positive common mode gain.
https://www.edaboard.com/showthread.php?384934-CMRR-is-less-than-the-DC-differential-gain
I use calibre, specifically select the ground node. All extracted sim results, noRC, CC,rcc_lm have positive common mode gain while prelayout has -42dB common mode gain. Simulated in open loop.
In transient open loop simulation, I am able to observe common mode transient gain, which confirms with me that the positive common mode gain is true. Prelayout and post layout have very closed match of differentail gain and BW after excluding input referred offset voltage.
