Is it possible to read such common filter characteristics using LibreVna? I have several desoldered filters and I would like to find out as much information about them as possible. If so, how to connect them to the VNA?
I read your VNA has a lower limit of 0.1 MHz.
What spectrum are you hoping to measure?
What parameter is most important to you?
Zcm(f), Zdm, SRF or CMRR(f)
For correct measurement, you need symmetrical VNA ports. A common method is to use 4-port VNA as shown in appended Wuerth datasheet and transform to 2-port. The other option is to use wide band 1:1 baluns for both ports.
For a rough estimate of common mode rejection, I would measure this as a 2-port with inputs 1+2 connected and outputs 3+4 connected. That's essentially common mode, isn't it?
