Common Interview Questions
aditya1579
Member level 2
One of the common interview questions I face is :
While building a clock tree, what are some of the factors one should take care of ? Skew is one of the points which comes to my mind. What are the others ?
Maybe things like - which buffers to use to get minimum delay, which layers to route the clock wires on etc. ??
Aditya
while building a clock tree
There are three important parameters for such nets:
***Transition time:- This is the time it takes to change the logic level of a node (e.g. 0 ! 1).
***Insertion delay:- The time required for the signal to travel from the driver to the end-points.
***Skew :- Difference in clock arrival time at two spatially distinct points
