Common Emitter amplifier
Khan740
Junior Member level 2
Why there is phase change in Common Emitter Amplifier?
Syncopator
Full Member level 6
N.E. Lincolnshire U.K.
There isn't. There is an inversion.
When the base of an NPN transistor goes positive the base-emitter current increases, and so, therefore does the collector current.
The increase in collector current produces a larger voltage drop across the collector load. The collector voltage therefore goes less positive.
And vice versa for a negative change at the base.
In a PNP transistor the action is similar, but the polarities are opposite to the NPN case.
