colloidal silver generator
kesmez
Newbie level 6
This is colloidal silver generator. I have designed. It's Sprint layout file.
https://www.2shared.com/file/7159225/d1235095/silvergenerator.html
layout file viewer
This is circuit schema. The circuit has been tested running.
It work with 220 volt ac or 9-30 V dc batteries . Average input power of the circuit is less than 1 watt. The current set of electrodes 20 is ma .. Uc3843 was used in the circuit. Output can produce maximum 38-volt . Output do not more than 20mA while output short-circuit ..
silver generator
Great work! You would be able to say something about it, that silver with a what kind of quality is capable of the production of colloid? Until how many minutes is it necessary to use it?
colloidal silver generator schematics
I think 5 minutes is sufficient for 10 - 30 ppm colloidal silver. I havent ppm meter. If it is not fast enough. R4 must be increment for example 22k
What about t1 and r4. It is voltage to current converter for level shift (silver output voltage).
colloidal silver generator uk
I love looking at other people's ideas. I have a question about the circuit. Does the silver bath need to always be 12V above ground? It could get tingly if you put one hand in the bath and the other on the table.
silver generator schematic diagram
Bonjour,
Je suis interessé par votre circuit imprimé.
J'aimerai réaliser un générateur d'ag à partir de vos plans.
Où en êtes vous de vos essais?
Bien cordialement
