jokester4u
Junior Member level 2
How do i set a time for a line follwing r0b0t when it start from one place and when it get reversed it should stop on the same location where its started?
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 #include<reg2051.h> unsigned int m; void delay() {for(m=0;m<=20;m++) { TMOD=0X01; TL0=0xFD; TH0=0X4B; TR0=1; while(TF0==0); TR0=0; TF0=0;}} /// one sec delay sbit L=P3^2; sbit M=P3^3; sbit R=P3^4; void main () { P1=0x00; P3=0xFF; if (L==1&&M==0&&R==1) {P1=0x05;} // forward else if (L==1&&M==1&&R==1) {P1=0x0A;} } // reverse
#include<p89v51rd2.h>
unsigned int a=0,steps=0,b=0;
void Timer(void) interrupt 1 // Interrupt No.1 for T0
TH0=0x4b;
TL0=0xfc;
if(a==20)
steps++; // after 1 sec
a=0;
// if stop is signaled for the robot,stop the timer
a++;
void Timer1(void) interrupt 3 // Interrupt No.3 for T2
TH0=0x4b;
TL0=0xfc;
if(b==20)
steps--;
b=0;
if(steps==0)
TR1=0; // stop timer
// stop the robot
b++;
void main()
unsigned int fwd=0,rev=0;
TMOD = 0x11; // Mode1 of Timer0 & mode 1 of timer 1
IEN0 = 0x8a; // Enable interrupt
while(1)
if(fwd==1)
TH0=0x4b; // Initial values loaded to Timer
TL0=0xfc;
TR0=1;
if(rev==1)
TH1=0x4b; // Initial values loaded to Timer
TL1=0xfc;
TR1=1;
