coding for SYNCHRONOUS FIFO implementation with diff clocks?
dav
Newbie level 1
hi everyone...
Can anyone send me some links or vhdl code for SYNCHRONOUS FIFO implementation in FPGA having different read and write clocks ????.
-dav..
Re: coding for SYNCHRONOUS FIFO implementation with diff clo
Why dont you just write the code for this yourself?
Its not hard, just a bit time consuming.
E
search on this forum for CDC clock domain crossing
XIlinx actually provide that fifo. Why do you need to implement ur self?
GO to check Xiilnx Library... FIFO36 or FIFO18. There are some block diagram provided for you to implement if you want. Thanks.
google sunburst design fifo. they have code as well good explanation
