ecestar
Newbie level 5
code with c
can any one helpe me i write cde with c language to measure the value of frequency wich input to the microcontroller and display character to each value by using lcd.
the prpblem is when i put constant frequency that input the 8051 then i have
on the lcd many caracter for each time .
can any one help me please and this is my code
#include <reg66x.h>
#include <reg52.h>
#include <stdio.h>
#define NewLine 0xc0
#define ClrDisp 0x01
#define TwoLine10dots 0x38
#define ScrOnCurOffBlinkOff 0x0F
#define IncCurDntMovDis 0x06
#define OUT P1
int check ;
sbit BusyFlag=P1^7;
sbit RS =P3^5;
sbit RW =P3^6;
sbit E =P3^7;
Timer 0 Overflow Interrupt
unsigned long tt ;
unsigned long t;
void T0_ISR (void) interrupt 1
TF0 = 0; // Reset the interrupt request
MAIN C function
int temp(){
int x,y;
y=tt/335;
x=y+31;
return x;
void checkBusy(void){
OUT=0XFF ;
do{ ;
E =0;
RS =0;
RW =1;
E =1;
}while(BusyFlag);
E=0;
RW = 0;
void sendCmd (unsigned char Cmd){
checkBusy();
RS = 0;
RW = 0;
OUT = Cmd;
E =1;
E =0;
void sendData (unsigned char ch){
checkBusy();
RS = 1;
RW = 0;
OUT=ch;
E = 1;
E = 0;
void init_LCD (void){
sendCmd(TwoLine10dots);
sendCmd(ScrOnCurOffBlinkOff);
sendCmd(IncCurDntMovDis);
void main (void)
int a;
Set serial port for 9600 baud at
11.0592 MHz. Note that we use Timer 1
for the baud rate generator.
SCON = 0x53;
PCON =0x00;
TH1 = 0xFA;
TL1 = 0xFA;
TR1 = 1;
TI = 1 ;
Enable interrupts for timer 0.
ET0 = 1;
EA = 1;
Set Timer0 for 16-bit interval timer
mode.
TMOD = 0x21;
while (1)
Clear the timer overflow counter and
the timer low and high registers. Then,
start the timer.
TH0 = 0;
TL0 = 0;
TR0 = 1;
Wait for the pulse to start.
Then, wait for the pulse to end.
while (!INT0);
while (INT0);
Compute the width of the pulse -- one
clock cycle is 1us for a standard 8051
and display it.
tt=((unsigned long)(TH0*256)+TL0) ;
printf ("%1d\n",tt=(unsigned long)(TH0*256)+TL0) ;
a=temp();
if (a==32){
init_LCD();
sendCmd(ClrDisp);
sendData('A');
sendCmd(NewLine);
for(t=0;t<1000;t++){}
else if (a==33){
init_LCD();
sendCmd(ClrDisp);
sendData('b');
sendCmd(NewLine);
else if (a==34){
init_LCD();
sendCmd(ClrDisp);
sendData('c');
sendCmd(NewLine);
else if (a==35){
init_LCD();
sendCmd(ClrDisp);
sendData('d');
sendCmd(NewLine);
else if (a==36){
init_LCD();
sendCmd(ClrDisp);
sendData('e');
sendCmd(NewLine);
else if (a==37){
init_LCD();
sendCmd(ClrDisp);
sendData('f');
sendCmd(NewLine);
else if (a==38){
init_LCD();
sendCmd(ClrDisp);
sendData('g');
sendCmd(NewLine);
else if (a==39){
init_LCD();
sendCmd(ClrDisp);
sendData('h');
sendCmd(NewLine);
else if (a==40){
init_LCD();
sendCmd(ClrDisp);
sendData('i');
sendCmd(NewLine);
else if (a==41){
init_LCD();
sendCmd(ClrDisp);
sendData('j');
sendCmd(NewLine);
else {
// for(t=0;t<10000000;t++){}
// for(t=0;t<10000;t++);
#include <reg66x.h>
#include <reg52.h>
#include <stdio.h>
#define OUT P1
int check ;
sbit BusyFlag=P1^7;
sbit RS =P3^5;
sbit RW =P3^6;
sbit E =P3^7;
unsigned long tt ;
unsigned long t;
MAIN C function
int temp(){
int x,y;
y=tt/335;
x=y+31;
return x;
OUT=0XFF ;
do{ ;
E =0;
RS =0;
RW =1;
E =1;
}while(BusyFlag);
E=0;
RW = 0;
checkBusy();
RS = 0;
RW = 0;
OUT = Cmd;
E =1;
E =0;
checkBusy();
RS = 1;
RW = 0;
OUT=ch;
E = 1;
E = 0;
void main (void)
int a;
SCON = 0x53;
PCON =0x00;
TH1 = 0xFA;
TL1 = 0xFA;
TR1 = 1;
TI = 1 ;
ET0 = 1;
EA = 1;
mode.
TMOD = 0x21;
while (1)
start the timer.
TH0 = 0;
TL0 = 0;
TR0 = 1;
while (!INT0);
while (INT0);
and display it.
a=temp();
if (a==32){
init_LCD();
sendCmd(ClrDisp);
sendData('A');
sendCmd(NewLine);
else if (a==33){
init_LCD();
sendCmd(ClrDisp);
sendData('b');
sendCmd(NewLine);
else if (a==34){
init_LCD();
sendCmd(ClrDisp);
sendData('c');
sendCmd(NewLine);
else if (a==35){
init_LCD();
sendCmd(ClrDisp);
sendData('d');
sendCmd(NewLine);
else if (a==36){
init_LCD();
sendCmd(ClrDisp);
sendData('e');
sendCmd(NewLine);
else if (a==37){
init_LCD();
sendCmd(ClrDisp);
sendData('f');
sendCmd(NewLine);
else if (a==38){
init_LCD();
sendCmd(ClrDisp);
sendData('g');
sendCmd(NewLine);
else if (a==39){
init_LCD();
sendCmd(ClrDisp);
sendData('h');
sendCmd(NewLine);
else if (a==40){
init_LCD();
sendCmd(ClrDisp);
sendData('i');
sendCmd(NewLine);
else if (a==41){
init_LCD();
sendCmd(ClrDisp);
sendData('j');
sendCmd(NewLine);
else {
