Device = 16F877
' Define program variables
Dim Col as Byte ' Keypad column
Dim Row as Byte ' Keypad row
Dim Key as Byte ' Key value
Delayms 100 ' Wait for LCD to start
PORTB_PULLUPS = ON ' Enable PORTB pullups
ALL_DIGITAL = True ' Set ports to digital mode
Print Cls, "Press any key" ' Display sign on message
Loop: Gosub Getkey ' Get a key from the keypad
Print Cls, #Key ' Display ASCII key number
Goto Loop ' Do it forever
' Subroutine to get a key from keypad
Getkey:
Delayms 50 ' Debounce
Getkeyu:
' Wait for all keys up
PORTB = 0 ' All output pins low
TRISB = $F0 ' Bottom 4 pins out, top 4 pins in
If (PORTB >> 4) <> $0F Then Getkeyu ' If any keys down, loop
Getkeyp:
' Wait for keypress
For Col = 0 to 3 ' 4 columns in keypad
TRISB = (Dcd Col) ^ $FF ' Set one column pin to output
Row = PORTB >> 4 ' Read row
If Row <> $0F Then Gotkey ' If any keydown, exit
Next
Goto Getkeyp ' No keys down, go look again
Gotkey: ' Change row and column to key number 1 - 16
Key = (Col * 4) + (Ncd (Row ^ $0F))
Return ' Subroutine over
Label:
End
