Code for automatic change of unix shells to bash
ravet
Member level 5
DSO
Hello
i want to write a shell script that can be able to change the shell, i.e. i wrote a code that can run correctly in bash and not in csh, so, i want to add something in the code so that it automatic can change the shell to bash, whatever the current shell is, and after finishing , it automatically reload the previous shell....
thanks
Re: unix shells
use "magic number" #! at the first line of the script, for example
#!/bin/bash
this specify, which shell will be used to execute the script, see:
h**p://www.faqs.org/faqs/unix-faq/faq/part3/section-16.html
blue_snake
Re: unix shells
Hi
You can specify the interpreter (and options) for the script at the beginning of the script as "#<path to the interpreter>".
Eg: #!/bin/bash
#!/bin/sh
#!/usr/bin/perl
unix shells
When your shell script exits, no matter which language or interpreter you use, the previous environment is restored. Which means you're are already automatically back to your original shell.
