yousafzai82
Member level 4
Hello everyone....
I want to programme pic16f877 2 channel 10 bit adc. I need two digital inputs as well. The program should send AT commands for SMS then the Value1, Value2, Status1, Status2 shown in the program below.
If you can edit the Coding as 2 channel 10-bit ADCs only send the values as i.e.
Value1= 0 to 1023
Value2= 0 to 1023
Status1= High or Low
Status2= High or Low
Someone please suggest modification how to code Status1 and Status2 using RA4,RA5. Is my current program ok? It is urgent..
The program should send SMS continuously after some time say 5 minutes.
Zaky
_________________
Added after 3 hours 53 minutes:
I modified the code as follows. Is it alright. Will i be able to send the data this way????
Value1= 0 to 1023
Value2= 0 to 1023
#include<16F877.h>
#device ADC=10
#fuses HS,NOWDT,NOPROTECT,NOLVP,NOBROWNOUT,PUT
#use delay(clock=10000000)
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,stream=RS232,bits=8)
#include<stdio.h>
#include<math.h>
#include<STDLIB.H>
#Byte PortA=0x05
#Byte PortB=0x06
#use fast_io(A)
#use fast_io(B)
#Define Nop #Asm Nop #EndAsm
int fuel, temp;
void send_SMS(void)
printf("AT\r\n");
delay_ms(5000);
printf("at+cmgf=1\r\n");
delay_ms(5000);
printf("at+cmgs=\"+4478XXXXXXXX\"\r\n");
delay_ms(5000);
printf("%f/n/rfuel: %f/n/rtemp",(float)fuel,(float)temp);
putc(0x1A);
delay_ms(5000);
void main(){
setup_adc( ADC_CLOCK_INTERNAL );
setup_adc_ports( RA0_RA1_ANALOG_RA3_REF );
set_adc_channel(0);
SET_TRIS_A( 0b10000110 );
SET_TRIS_B( 0b00000101 ); delay_ms(1);
while(1){
delay_ms( 30000);
delay_ms( 30000);
delay_ms( 30000);
delay_ms( 30000);
delay_ms( 30000);
delay_ms( 30000);
delay_ms( 30000);
delay_ms( 30000);
delay_ms( 30000);
delay_ms( 30000);
fuel = read_adc();
set_adc_channel(1);
temp = read_adc();
send_SMS();
Zaky
_________________
#include<16F877.h>
#device ADC=10
#include<stdio.h>
#include<math.h>
#include<STDLIB.H>
#Byte PortA=0x05
#Byte PortB=0x06
#use fast_io(A)
#use fast_io(B)
int16 fuel, temp;
int1 Genset, CP;
void send_SMS(void)
printf("AT\r\n");
delay_ms(5000);
delay_ms(5000);
printf("at+cmgs=\"+923469400983\"\r\n");
delay_ms(5000);
printf("%f/n/rfuel: %f/n/rtemp:%d/n/rGenset:%d/n/rCP:",(float)fuel,(float)temp,Genset,CP);
putc(0x1A);
delay_ms(5000);
void main(){
set_adc_channel(0);
while(1){
delay_ms( 30000);
delay_ms( 30000);
delay_ms( 30000);
delay_ms( 30000);
delay_ms( 30000);
delay_ms( 30000);
delay_ms( 30000);
delay_ms( 30000);
delay_ms( 30000);
delay_ms( 30000);
fuel = read_adc();
set_adc_channel(1);
temp = read_adc();
Genset = input_state(pin_A4);
CP = input_state(pin_A5);
send_SMS();
