CoCentric System Studio (CCSS) or Modelsim for SystemC
jimjim2k
Advanced Member level 3
Hi
CoCentric System Studio (CCSS) includes a release of SystemC.
Modelsim comes with a GCC supports SystemC.
Does someone have suggestions on using whichever of them?
tnx
computer_terminator
Member level 3
systemc-2.0.1.exe
Use modelsim.
It is easy to comiple various design languages together.
If you only use systemC, you can use gcc + gdb, and dump VCD.
And then, use waveform viewer(debussy) to see the VCD waveform.
omara007
Cairo/Egypt
ncsc cadence
Does Modelsim that's under windows support SystemC ?
O
omiga
concentric systemc
can anyone upload some document about systemc?
mhmhmh
Full Member level 3
scv library on cygwin
Hi
to omara007, they support only Linux, SunOS and HP-UX
to omiga, very good doc about systemc : h--p://www.synopsys.com/products/sld/rtl_systemc.pdf
Best reg
computer_terminator
Member level 3
systemc compiling in gcc
I used cygwin gcc to compile the systemC library under windows,
and run simulation well in cygwin env.
CatKing
Full Member level 3
synopsys concentic systemc compiler
All there:
hxxp://www.ti.informatik.uni-bonn.de/Extern/systemc/SystemC_und_Doku/
FuncSpec20.pdf 04-Apr-2002 17:47 324k
SystemC_v201_LRM.pdf 10-Sep-2003 11:29 3.4M
UserGuide20.pdf 05-Apr-2002 23:42 1.3M
rtl_systemc.pdf 06-Sep-2002 10:57 948k
systemc-2.0.1.exe 25-Jul-2002 12:58 1.9M
multiplier
Newbie level 2
incisive debussy waveform dump
From within the synopsys DC environment
you can compile your systemc file with the following command
compile_systemc my_design.cpp
The output is in .db format. If you need the output in Verilog or VHDL format you enter the command
compile_systemc -format {db, verilog, vhdl} my_design.cpp
you get the files my_design.v and my_design.vhd with the verilog and vhdl equivalent description.
Afterthat, you can proceed to compile
You don't have to do analyze and elaborate
ram
cocentric system studio modelsim
why dont you try for NCSC ..cadence systemc compiler
galant
Member level 3
systemc_v201_lrm.pdf
Furthermore, Cadence is also the member of OSI. And Cadence expaned the standard systemc in its Incisive platform.
haifengyuyun
Member level 1
debussy systemc gcc
summit's Elite is good and support SystemC ,can compile and simulation see waveform easy
ram
systemc debussy
Cadence has a very good support for systemc. These people also have CVE cadence verification extentions. These are similar like SCV
zhangpengyu
Full Member level 3
systemc ncsc
modelsim will be good.
But I use vcs,which has good support to systemc.
oxford
Member level 2
which cygwin for systemc 2.0
Modelsim 6.0 support systemC now, you can try it.
omara007
Cairo/Egypt
compilar systemc gcc
Cocentric System Studio is much more complicated thhan ModelSim .. ModelSim just gives you what u want exactly to the point .. for example, u can simply add a file to an existing project in modelsim , while in Cocentric most of the time u will need to creat a new model for the file u need to add ..
Effectively I do use both ModelSim and Cocentric, but I'm forced to use Cocentric and not very flexible dealing with it .. Maybe because am a ModelSim fan ..
To be honest, Cecentric gives u some more facilities like plotting the output of ur blocks .. similar to matlab .. for this , it can more suitable for system level design and verification .. while for modelsim, most of the people use it for RTL ..
eeeraghu
Full Member level 4
systemc & ncsc
Model sim 6.0 windows do support system C, And the versions from 5.7 modelsim LE, supports system c.
How about learning System C Using the ALDEC tool which is free (only for learning)
zhaoyimiao
Member level 1
SystemC
Concentric SystemC is for algorithm, system and architecture design. ModelSim system is more for verification.
