Slevinus
Newbie
Hello everyone.
I am designing a coaxial co-linear antenna with 8 elements and with end-feed, not center. I could not decide the best option to analyse structure via software. I chose every elements properties but i am not sure if CST can handle with the antenna. Which solver could be usefull for analysing Co-Co antenna? In Cst, i am trying to feed the antenna with 50 Ohm coaxial line then position the elements after feed line and use waveguied port to feed the coaxial line. Is this the correct method?
Thank you.
Thank you.
