Coaxial cable bandwidth
1icarus1
Junior Member level 3
coaxial cable bandwidth
Hallo there,
I would like to add a low frequency data signal with the video signal in order to have a comunication between a master and a slave. Could I choose the frequencies 50KHz for the "0" and 100KHz for the "1". Is this frequency good for a coaxial cable which drives the video signal simultaneously?
Thank you all.
coaxial cabele bandwidth
What kind of video are you talking about? Is it baseband video or is it a TV rf signal? In the case of baseband video you can not use FSK as you intended. Frequencies must be higher tnan 10MHz. In the case of TV rf signal your idea is OK.
