What is the best choice in rail-to-rail input stages, concerning the CMRR in all the range of operation????
Because in the transition region, the CMRR are degraded a lot using complementary differential pairs.
What could be a good topology to overcome this problem?
Thanks a lot!
Filipe
using a kind differential pair to perform r2r input range, and using charge pump to boost the corresponding power supply voltage, this may be a solution.
