calculus_cuthbert
Member level 4
CMOS Amplifier Design
I need to design a differential to single ended amplifier with negative feedback (to control the gain). The input is a differential signal so i need both terminals
The simplest would be a diff pair but how do i implement negative feedback because i need to use both the input terminals?
I thought about a few options:
1. Designing an opamp and then using resistors to build a difference amplifier
2. The input impedance may be a problem if i use a difference amplifier, so may i need to design an instrumentation amplifier.
Is there a more elegant way to implement controllable gain differential to single ended converter?
I need to start designing soon, I would really appreciate if someone could suggest ideas.
Thank you.
Thank you.
