CMOS level shifter for changing a square wave from 0-1.8v to 1.8-3.6v
gtmbht
Newbie level 3
Hello,
I would like to shift a square wave operating between 0-1.8v to one operating between 1.8-3.6V. I tried using a conventional level shifter (domino like circuit). Unofrtunately it only shifts the upper level and not the lower , i.e., the wave output is between 0-3.6V and not 1.8-3.6V (desired). Please help me with this issue
Thanks
Gautam
IanP
Advanced Member level 5
West Coast
level shifter cmos
One option is to use summing opamp + (-X) inverter ..
Regards,
IanP
Reactions: JanIan
    JanIan
echo47
USA
cmos level
If you don't mind a momentary startup glitch, you could use a DC blocking capacitor, and bias the right side to 2.4v with resistors.
Davood Amerion
Advanced Member level 2
Persia
cmos level shifter design
Check following circuit, it is very simple, but may working.
You must change resistor value , respect to logic famili used.
:D
Dillon
Junior Member level 2
cmos level shifting
:D
It's a good method
sunil_ic
Newbie level 5
check attached circuit. instead of 2Vdd, apply 3.3V and, instead of Vdd apply 1.8V.
Rgd
