cluster: eesofg2p, ads momemtum
moss88
Newbie level 1
Newbie level 1
hi everyone
I've worked in a CPW power divider at ADS momemtum 2011.05. When I run the simulation process, the software shows this menssage:
Cannot start the cluster: eesofg2p crashed.
I don't know what is the problem!!!
I've used a work station Dell precision
I need some help to solve this technical problem.
I had a similar problem on my hp. I have found out you have to limit the number of CPUs that are allowed to be used by the simulation engine.
When you run the ADS open the task manager and locate hpeesofemx in processes, right click it and choose "set affinity"
un-mark "all processors" and allocate some of the CPUs (not all) and rerun the simulation reduce the number. if it crashes again reduce the number of CPUs.
I hope this will solve the issue
Hi!
I have the same problem but the proposed solution didn't work for me.
Moss88, have you found another solution?
Thanks
