Closed loop stability in Eldo
elmolla
Full Member level 2
eldo .lstb
Hey,
Anyone knows how to measure the closed loop stability and phase margin in Eldo or any of Mentor tools without breaking the loop??
lstb + eldo
use .lstb statement
works good, look manual
    elmolla
measure open loop gain with eldo
Why do you need check the closed-loop's PM? Generally, the phase margin is for open-loop.
loop gain simulation eldo
Thanks ch1k0.
trashbox, the PM is a measure of the closed loop response speed. We usually prefer our phase margin to be 60 degrees to have good speed without ringing response.
lstb middlebrook
There is something weired with the .lstb command
I added the zero source and tried the .lstb command
Sometimes it works and others not! Is there any condition or special simulation setup for it to work out?
stability analysis eldo
only works single loop. has bug if wrong version eldo. tried another version?
.extract command in eldo
hi,
.lstb Vlstb
VLSTB NET30 VMOINS DC 0 AC 0
* .lstb This command improves the analysis of circuit stability.
* The .LSTB command measures the loop gain by successive injection (Middlebrook
* Technique). A zero voltage source is placed in series in the loop: the first pin of the voltage loop
* must be connected to the loop input, the other pin to the loop output.
.AC DEC 10 1 1e10
.tran 1n 1n
*.PROBE ac lstb_db lstb_p V(****)
*extracts for open-loop analysis
.EXTRACT AC LABEL = gain_dc YVAL(lstb_db,1)
.EXTRACT AC LABEL = phase_margin YVAL(lstb_p,extract(gb_product))+180
.EXTRACT AC LABEL = gb_product XDOWN(lstb_db,0,1)
.EXTRACT AC LABEL = tau 1/(2*3.14159*extract(gb_product))
IT WORKS
hope that's helpful
Gafsos
differential loop stability probe
Has anyone found a way to do .lstb for differential circuits? Breaking a differental loop will require two voltage sources.
