Clock Tree Synthesis and RTL synthesis
anishjp
Full Member level 1
Johannesburg, South Africa
Hi all,
Do we have to do 'Clock tree synthesis' separately? or will it be done during the time of RTL synthesis.
Clock tree synthesis has to be done after RTL synthesis ......
Re: Clock Tree Synthesis
in physical design, clock tree synthesis should be done after placement.
add, up/down size buffers to meet your timing constraints...
Reactions: ivlsi
    ivlsi
maybe differernt flow
clock tree synthesis has to be done separately. It is done in the physical design after standard cell placement
Reactions: ehas
    ehas
what about the rst network ? Is it treated the same as the clock?
yes rst signal also treated as clock, but the specifications are not that much constrained,why this be build tree is rst signal is high fanout net.to minimize trasitions we build tree for this signals.
