[SOLVED] Clock module recommendations
Hi, I'm trying to create a PWM to control a servo motor, and was wondering what a good clock module to use would be.
KlausST
Super Moderator
Staff member
I don't understand.
To generate a PWM you first need to consider:
* expected PWM frequency (range)
* resolution (steps)
The
PWM module basically is just a (binary) counter and a (binary) comparator.
..maybe a flipflop for the output
With
Multiply PWM_frequency with resolution to get counter_clock_frequency
Example: PWM_frequency = 1 kHz, resolution = 256 steps
--> Counter_clock_frequency = 256 kHz
As always:
To generate the Counter_clock_frequency:
don't use clock dividers to generate a new_clock,
but use dividers to generate a count_enable_signal
Klaus
dpaul
Germany
Assuming you want to make an FPGA based design, it depends on which FPGA you are using. Unfortunately you have not explained anything in details.
I don't understand.
The
With
As always:
Klaus
Apologies my description is vague, still extremely new to this. I mean a physical chip that is actually generating a clock. I understand how to manipulate the signal once it reaches the CPLD.
The hardware im using is the Xilinx CoolRunner-II CPLD Processor, C-Mod Board. From my understanding the chip does not have an inbuilt clock and requires an external one to be connected.
If you need further information I will clarify.
Thanks for your patience!
KlausST
Super Moderator
Staff member
Yes, the CPLD needs a clock.
The requirements according frequency range, and voltage levels are given in the CPLD datasheet.
There are many clock_oscillator manufacturers and even more clock_oscillator types.
Many are suitable.
The first thing you need to do:
Decide your requirements. The voltage levels are given. So basically you need to decide the frequency.
My recommendations:
* If possible use only one clock source for CPLD internal logic
* focus on those parts (frequencies) that need a very fixed clock (no "range". Like UART, USB...).
* A higher frequency clock gives more flexibility (as you can simply divide it down)
Klaus
Many are suitable.
My recommendations:
Klaus
Ok perfect, thank you. I was searching clock modules (coming from arduino) but the refined search of clock_oscillator pinpoints exactly what I have been trying to search for.
The other tips are much appreciated :D
KlausST
Super Moderator
Staff member
when I read "Arduinio" I think of the many users here to run such designs on a breadboard.
--> Please don´t waste your time with a breadboard. It is not suitable for high frequency signals.
Frequency selection:
Let´s imagine you need
* a PWM frequency range of 1000Hz to 2000Hz with 256 steps resolution.
* a UART with baud rate of 38400 and 8 times oversampling
* A microcontroller that needs 8 MHz
Maybe the microcontroller has a built in software RTC, then it needs a very accurate clock. no additional error.
The UART will work with a clock frequency error of +/-2%
The PWM frequency is uncritical at all.
so you need to look for a clock (uC) that has multiple integer of 8MHz --> 8, 16, 24, 32, 40, 48...MHz
Now you have to check UART frequency. 38400Hz x 8 = 307.8 kHz
8M / 307.8k = 26.04167 --> the next best integer is 26
now calaculate frequency error: (26 - 26.04167)/ 26.04167 = 0.0016 = 0.16% --> within +/-2%, so it´s O.K.
Although this says you may use a 8MHz oscillator, I´d recommend a 48MHz one for more flexibility.
(please do error calculations before buying)
Klaus
