clock frequency when doing scan capture
akrlot
Member level 3
scan chain tutorial
hi;
im wondering why we need to apply a clock pulse in fonctionnal mode?
could u give a good explanation for the scan sequence.
thanx
scan chain asic
Triggering clock pulse between scan shift is usually appeared in capture cycle. In which the injected test pattern has been applied to internal combo. logic. An extra clock pulse (capture clock) is used to latch the internal combo. output to scan FF and then shift out for measurement.
    akrlot
vector scan sequence
In order to test the manufactured design, the scan-chain method is often used.
Because the objective of scan-chain circuits is mainly to test the combinational logic between Flip Flops, the necessities to scan the stimuli to the inputs of the combinationa logic is required; however since the utility of scan-chain methods is to reduce the number of pins of the chip; therefore the serial method is always taken so that the scan clock should be utilized to transfer the serial stimuli into the parallel ones. Even if not, in order to test the large number of cones between the Flip flops, we can only test one of the cones at a time so that a scan clock is needed. Currently, there are two ways to test the function of the combinational logics: internal testing logic such as BSIT and external devices such as ATE which often is expensive and less tesing pins than the pins on the chip.
    akrlot
linking scan chains with separate clocks
basic scan sequence:
1) Apply data to primary input (PI)
2) Shifting in scan vector into scan chains through scan in (SI) pins.
3) Scan capture. In this state, scan enable pin is set to low.
4) Shifting out - measure primary output (PO) and Scan out (SO) pins
    akrlot
capture in scan chain
Can any body provide some link for scan chain tutorial?
Thanks,
Jitendra
scan chain book
In fact, we apply a clock pulse in test mode called capture cycle
scan capture clock
Thanks,
Jitendra
search for the book Digital.Logic.Testing.And.Simulation in ebooks upload/download section of this forum
scan chain primer
in order to capture test data !!!
    akrlot
scan chain example
akrlot : thank you very much for as follows:
This is thanks message from akrlot for your message that you sent: You are very valuable member thats why you have received 3 points from us. Automatic generated message.
let's study together !!! best regards!!!
    akrlot
apr scan chain
apply a clock puls is to capture internal generated signal into shift register.
akrlot said:
hi;
thanx
