defination of theoretical
While working on the real UWB system, I used both PPM and OOK modulated transmit signals. In either case, the same pulse shape and therefore the same pulse energy is used. For PPM the average energy is taken as Eb and for OOK as Eb/2.
Further, two different receiver positions were chosen for simulation environment. The two positions are separated by 2m.
While analysing the simulated result from either modulation scheme, I require theoretical baseband equations. The simulation of two channels deliver nearly the same performance curve.
The theoretical limit for PPM is taken as Q(sqrt(Eb/N0)) while for OOK as Q(sqrt(0.5*Eb/N0)). Are these equations correct? Secondly, comparing these equations to the simulated result leads to some theoretical violation? (lower bound violation).
I am still ambigous if that can be applied to OOK. Please comment urgently.
I am feeling that the simulations are not wrong but the performance bounds are not set correctly. Can someone clearly state the theoretical equations for the two modulation schemes?
Thanks
