crystalballs
Member level 1
Hello all,
I read form Chap6 of the book "design of analog integrated circuits and systems" by Laker/Sansen:
In an OTA... A node is counted only if it has a high impedance...
...the single transitor amplifier is a two-node circuit.
...The input node is connected to the input source Vin over a source resistance Rs...
The differential amplifier...is still a two node circuit...
...The input terminals do not count as nodes because they are connected directly to an input voltage source...
WHY, about input impedance, is not the same for a single-transistor and differential amplifiers?!
WHY the input signal should be connected through an Rs for the first case and not for differential amplifier?
Attached is the page of that book.
TIA!
CBs
TIA!
CBs
