Clarification on DTMF
prasannabalaji
Junior Member level 1
hi,
i am using MT8880 which is a DTMF transceiver..after initialisation of control reg i am giving the input of 7 i want to know, how to check that wheather this IC is txansmitting DTMF signal or not
thank u in advance
Prabakaran
Full Member level 3
Chennai(India)
Hi
Prasannabalaji,
check the MT8880 by using the CRO , check the output of DTMF and u can see there is some frequency comming out from that.
Can u send the details of MT8880 , its cost and circuit diagram of this , because i too using the same module , i couldn get the IC in the Market. so can u send the details regarding the cost of the IC and place where u got the Ic , and send me the Application circuit.
vinunandakumar
prasannabalaji said:
hi,
thank u in advance
try using a dtmf decoder like 8870
saubhik
Full Member level 3
India
A question which made me mad on my college days when I was doing the project on DTMF receiver.
After that what idea we have used I can explain it to u , I think it will help u to find out the answer very easily .
In a DTMF transmitter for any key press it generates two frequency signals (in Rake Receiver concept those signals are orthogonal to each other ) - one is of high frequency and another is of low frequency . Then if you know the frequecy range and what frequency the TX should generate then easily using filters u can separate the frequency signals and check in a CRO at the output of the filters ,. This method will help u to get the exact frequencies generated by the Tx.
Any how for ur help I am sending u the DTMF decoder IC details also which is preferred by Mr. vinunandakumar .....u can find it in the following link
I hope u can right now easily solve the problem ......
Ok and Bye ......
nandhu015
Advanced Member level 5
India
hi,
thank u in advance
just connect the output to a working telephone line. You can hear the tone
simple
Nandhu
