calton57
Banned
I always see these clamping diodes on the input pins of logic IC chips, mostly for TTL chips, any reasons why for TTL logic chips and not for CMOS logic chips?
The Clamping diodes are to protect the Input pins of the logic IC chips to go into the "negative region" which will damage the input section of the IC chip. Any reasons why the Logic IC chip doesn't like a negative voltage?
They make amplifiers with one transistors that swings both positive and negative voltages, but they use DC offset so the negative cycle voltage is not below ground or zero voltage.
What are some signals or Logic IC chips causes a negative voltage on the input to logic circuits or to a logic IC chips?
I read that Flip flops cause a negative output voltage signal which damages IC TTL logic chips, any reasons why flip flop chips output a negative signal or they call it a ringing
