Circular placement in PowerPCB
davorin
Advanced Member level 3
Switzerland
powerpcb placement
When I want to place 60 LEDs in 4 circles with 15 LEDs each PowerPCB isn´t capable of doing this correctly. Like not all LEDs are palced correctly on circle line...
So only way to place is only 1 circle at a time?
what i'll suggest is that first make the circal (sillkscreen top) and then place the 15 LED's...
save this placement and if u can use this as a reuse design then its ok..
other wise open the placement file, and add/change the component designation and location....do this four times...
other wise use VB script to add particular digit on LED location...
Ehhmm...this sounds more complicated than selecting 15 LEDs at a time and place them circular (o;
Try polar placement PL
you should be able to do it with eagle v4.1 or later.
Ehhmm...what has eagle to do with PowerPCB? (o;
I know it is possible in Eagle, CadStar 6 and PowerPCB...the topic is not about which PCB package can do circular placement (o;
power pcb can do it using polar co-or.
set angle required and simply go on placing the led this may the easy job
polor move is very good in powerpcb
binu george
I know that it is possible...please read the original question!!!
Question was if it is normal that placing several concentric circles at once has a bug....
Select 15 LEDs ---> RBM ---> Create array ---> Enter the inputs ---> OK-OK ---> Here you go..... Circular Placement in PowerPCB.
Hope this will answer your question.
OK, select one LED footprint and the type "Ctrl+I".
PLACE THE COMPONENTS USING RADIAL MOVE OPTION WITH REQUIRED SETUP
