circular microstrip patch antenna design with HFSS
akhanm
Newbie level 5
circular patch antenna design
Hi guys,
i have simulated rectangular microstrip antennas before, now i am looking for circular shaped one. How should i feed the patch? coax-prob needed or can microstrip line be used..
because circular MSA is not so populerly used antenna, i don't have document enough so then uploaded files will be pleasured
circular patch antenna hfss
Hello akhanm,
The Circular Patch model need to be fed by a coaxial line or probe from bottom as shown in the figure...For example
circular patch with Er=2.2,h=1.588mm,frequency=10GHz ,radius r=5.2492 mm
for equations & details on Circular Patch Antenna go through following book...
Constantine A. Balanis, " Antenna theory analysis and design" , john Wiley &
Sons second edition 1997 pp. 752-759
---manju---
Reactions: usrao75
    akhanm
    usrao75
patch antenna+hfss
Come on.... There are numerous circularly polarized examples in the literature. Try IEEE TAP. IRE will have many more. Most books on patch antennas will have chapters on the subject.
Look at the crop of GPS antennas in patch form. They are circularly polarized. Find an old one and cut it open to see how it may be accomplished.
Search or go to a good technical library.
design circular patch antenna
i have recently purchased thr Balanis book, thanks for advices
I need example for circular patch antenna on HFSS or CST
come on. if you have already simulated rectangular patch in HFSS, then what is the problem, i think in this forum you should discuss problem which means that you should at least try by yourself first and then ask for any problem.
For reference as to what should be the dimensions and all, please refer to Balanis Chapter-14 on microstrip patch antennas, where all the required values for simulations are clearly listed.
hope it helps.
Regards
Ashish
Dear All
I need your support to calculate parameter for Circular Microstrip Antenna in matlab.
a,ae,Gc,Gd,Grad,Qc,Qd,Qrad,Eff,Gain,D,etc
