LynB
Newbie level 1
I have a system comprised of commercial products. One unit is (basically) a linear motor, which I use to apply an oscillating force to a structure. The frequency range of the oscillations is 70-1600 Hz. The signal driving the linear motor comes from an amplifier that is capable of outputting a signal with a DC component, if it receives a low-voltage input signal with a DC component. A third unit is a low voltage signal generator that can only output AC signals. I want to add a DC component to the AC output of the signal generator so that I can apply a static as well as an oscillating force to the structure. What circuit do I need in order to do that?
Thanks for the help.
LynB
LynB
