circuit for remainder for divide by 64
sun_ray
Advanced Member level 3
Please provide a circuit that can provide the remainder when any 16 bit input to the circuit is divided by 64.
It's a bit strange when an experienced Edaboard member makes his questions sound like a first year's student homework problem...
Isn't the answer a simple part select (Verilog) respectively slice (VHDL)? You can also desribe it with a modulo operator.
please correct me if iam wrong
copy the dividend into MSB of 32 bit register , right shift 4 times you will get quotient [31:16] and fractional remainder [15:0]
FvM
Will that be synthesizable if modulo operator is used?
dipin
Can you please explain how is it bringing remainder?
modulo 2^n simpy synthesises as a shift operation, other numbers infer a divider core, if supported by the respective tool.
dipin
take number 22 ,it sbinary equals 0000 0000 0001 0110
copy it to MSB of 32 bit register 0000 0000 0001 0110 0000 0000 0000 0000
then 2^4 =16 ,so shift 4 times 0000 0000 0000 0001 0110 0000 0000 0000
22/16= 1.375
quotient(msb)=0000 0000 0000 0001 =1
(lsb) remainder(in fraction)=0110 0000 0000 0000 = 2^-2+2^-3
=.25+.125
=.375
the output fractional accurcy is depends upon the number of fractional bits we are using
regards
Just use bit 0 ...5 of the 16 bit input.
Or use "AND 0x003F".
