Circuit diagram for ATmega328p
JAMAL JIMI
Member level 1
Member level 1
Can anyone please give me a circuit diagram of the minimum circuit connections for Atmega328p????????????????
Can I use this microcontroller with out xtal and external reset circuit and with out programming the fuse bits????
Hi JAMAL JIMI
I'm not a programmer but as i've a programmer in my group i see what he is doing . he simply refer to the datasheet of that MUC and i saw it's dealing with everything in detail !
Best Wishes
Goldsmith
I am consulting the Atmel's datasheet can you please tell me on which page the circuit is drawn???
Dear.............
I have programmed an ATmega328p on the simulator and its working fine on the simulator but not working on the bread board.........:sad:
What can be the possible reason???
You can see a good working circuit diagram of a 328 here.
When using a breadboard you can often get poor connections on the fine leads of the crystal and its caps, fitting thicker leads to those 3 parts and keeping all wires as short as possible will help.
Have you got all your Fuses correctly set ?
http://www.engbedded.com/fusecalc
Dear.............
it can be gang of problems ! which frequency of clock you're using there ? try to do something as follows :
1= add a 100uF capacitor as near as possible with the supply pins of your MCU .
2- if your frequency is high , bread board simply can't suit the aim ! ( it's equivalent circuit instead of HF components of your clock pulse )
3- try to investigate on , connections of your wires on your bread board !
Good Luck
Goldsmith
