Feb 25, 2016 #1 kappa_am Full Member level 6 Joined Jul 16, 2012 Messages 331 Helped 19 Reputation 38 Reaction score 19 Trophy points 1,298 Location Vancouver Activity points 3,859 Hi all, I need to sense currents in a 600V, 800A inverter. which is better solution? CT or a series resistor along with isoamplifier? considering all feature of each solution as cost, saturation, reliability etc. Thanks
Feb 27, 2016 #2 B BradtheRad Super Moderator Staff member Joined Apr 1, 2011 Messages 15,203 Helped 2,901 Reputation 5,814 Reaction score 2,984 Trophy points 1,393 Location Minneapolis, Minnesota, USA Activity points 113,923 Also consider a hall sensor. At 800A you may find you can mount it near your wiring at some strategic angle or position, with no need to disconnect existing wires.
Feb 27, 2016 #3 F FlapJack Full Member level 6 Joined Sep 16, 2010 Messages 399 Helped 103 Reputation 206 Reaction score 100 Trophy points 1,308 Location USA Activity points 3,822 I do not think an 800+ amp resistor is reasonable. But a current transformer or current transformer with a hall sensor is a good solution. **broken link removed**
