I am thinking of using Gigabit Ethernet to have chip to chip interconnection.
How can I achieve this? Can I connnect Chip A to Chip B by SGMII without physical layer in between?
Chip A (GEMAC) -------> Chip B (GEMAC)
______________SGMII_______________
Thanks for your reply.
Can you tell me what IP can be implemented into a FPGA as PHY mode?
Since I am using Xilinx`s FPGA which doesn`t support SMII.
I would like to use SGMII and run at 100Mbps only to connect from FPGA A to FPGA B.
After small thinking, I got answer that is possible connect two chips directly without PHY or switch chip, by using SGMII or MII intefaces with MAC mode.
Look this:
