Check this VHDL code for calculating the gain of vertices
jyothikiranmai
Newbie level 1
Newbie level 1
hello, I want a help regarding this prog, Is it correct or not..???
this prog is to calculate the gain of the each vertices. the gain is the addition of weights(wt) in "initial_trail" prog. addition is done in "adder24" prog. the top module is "gain_cal".
library ieee;
use ieee.std_logic_1164.all;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
use IEEE.STD_LOGIC_SIGNED.ALL;
package FM is type int_vect is array (NATURAL RANGE<>) OF STD_LOGIC_VECTOR(3 downto 0);
type int_vect1 is array (NATURAL RANGE<>) OF STD_LOGIC_VECTOR(4 downto 0);
function conv1(ARG: INTEGER; SIZE: INTEGER) return STD_LOGIC_VECTOR;
end package FM;
package body FM is
function conv1(ARG: INTEGER; SIZE: INTEGER) return STD_LOGIC_VECTOR is
variable result: STD_LOGIC_VECTOR ((SIZE-1) downto 0);
variable temp: integer;
begin
temp := ARG;
for i in 0 to SIZE-1 loop
if (temp mod 2) = 1 then
result(i) := '1';
else
result(i) := '0';
end if;
temp := temp / 2;
end loop;
return result;
end conv1;
end package body FM;
---------GAIN_CAL-------
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use work.FM.all;
entity gain_cal is
port(ver : in STD_LOGIC_VECTOR(2 downto 0) ;
gain: out std_logic_vector(3 downto 0));
end;
architecture beh of gain_cal is
component initial_trail
port(current_ver : in STD_LOGIC_VECTOR(2 downto 0);
next_ver: in integer;
wt: out STD_LOGIC_VECTOR(3 downto 0));
end component;
component adder24
port (
A : in STD_LOGIC_VECTOR(3 downto 0);
B : in STD_LOGIC_VECTOR(3 downto 0);
OUTPUT : out STD_LOGIC_VECTOR(4 downto 0)
end component ;
-- signal nv : STD_LOGIC_VECTOR(2 downto 0);
signal w: int_vect(0 to 7);
signal g: int_vect1(1 to 6);
begin
label1: for i in integer range 1 to 6 generate
begin
w(0)<="0000";
-- nv<=conv1(i,3);
u1: initial_trail port map(ver,i,w(i));
u2:adder24 port map (w(i-1),w(i),g(i));
w(i+1)<=g(i)(3 downto 0 );
end generate label1;
gain<=w(7);
end beh;
--ADDER24----
library IEEE;
entity adder24 is
port (
end adder24;
architecture Behavioral of adder24 is
signal A_INT : SIGNED (4 downto 0);
signal B_INT : SIGNED (4 downto 0);
signal OUTPUT_VAR : SIGNED (4 downto 0);
begin
A_INT <=SIGNED(A(3) & A);
B_INT <=SIGNED(B(3) & B);
OUTPUT_VAR <= A_INT + B_INT;
OUTPUT <= STD_LOGIC_VECTOR(OUTPUT_VAR);
end Behavioral;
---INITIAL_TRAIL--
library ieee;
use work.FM.all;
entity initial_trail is
end;
architecture beh of initial_trail is
begin
wt<="1111" when current_ver="001" and next_ver=2 else
"0001" when current_ver="001" and next_ver=3 else
"1111" when current_ver="010" and next_ver=1 else
"0001" when current_ver="010" and next_ver=3 else
"0001" when current_ver="011" and next_ver=1 else
"0001" when current_ver="011" and next_ver=2 else
"1111" when current_ver="011" and next_ver=4 else
"1111" when current_ver="100" and next_ver=5 else
"0001" when current_ver="100" and next_ver=6 else
"1111" when current_ver="101" and next_ver=4 else
"0001" when current_ver="110" and next_ver=4 else
"0000";
end beh;
plz reply me -- immediately.
thnxs
jyothi.
nxtech
Full Member level 5
Full Member level 5
NO HIDDEN LINKS
Re: VHDL CODE
Are you kidding?
No one can tell you if the program is correct. They may be able to tell you that you have some syntax errors, but until you compile and simulate and then provide the results of that simulation based on your inputs no one will be able to offer any help.
E
